Boobala
You mentioned you messed with the governor setting ........ maybe that's the problem ..because if you have the linkage and SPRINGS installed properly ..all should be working...Since I don't know what you did with your governor setting ... I suggest you watch this
youtube video ... THIS is TARYL ... HE is a comedian ...so put-up with the first few min. of his foolishness ... but HE ... is a VERY SMART
mechanic ... watch & learn ...
........... https://www.youtube.com/watch?v=XbFyGRixoGA
I'm hoping the INTERNAL governor linkage is NOT the problem ..watch and listen to THIS video very carefully ... Boobala
