Craftsman 6.5 starts then stalls
nomowerproblems
Hello,
New to the forum, new to owning my own mower. I have zero experience with small motors. Here is what's happening. I bought a mower used. It's a craftmans 6.5 eager1 self propelled push mower. It was supposed to run great... it doesn't. I can start it then immediately it stalls. I've been watching YouTube videos and working on it for 7 hours now. I'm persistent. I want to fix this. Please help?
I checked compression - good!
I changed the oil - good!
I pulled the carb bowl and cleaned n sprayed it down, it was clean prior - good!
I got a new spark plug, it sparks - good!
I go to start it back up. I can't even start it now. I prime it up, then it'll start then stall.... still...
I included some pictures. For starters, what controls that rod with spring connected to the carb? If I reach my hand in there, it moves beautifully but nothing I do from the outside moves that rod. Am I missing something? Any help would be awesome. I feel like it's a fuel issue?
Mike
I should also add to that. I drained the gas tank and did a good cleaning with it to. Gas was clean. I out a stabilizer in their to rid any water just in case.
The gasket in between the carb and air cover was toast. I realize this could be it. It'll be a few days until the new one comes in the mail. Any thoughts?
That rod is the governor rod. The engine uses it to maintain a consistent running speed. As long as it is hooked up correctly and is not damaged, leave it alone.
If I were you, I would clean the gas tank and replace the carburetor and fuel line. You have a Tecumseh engine, and Tecumseh carburetors are extremely hard to clean correctly. Sometimes they won't work right even if they are cleaned correctly! :confused2:
I will look up the carburetor and give you the part number later. Have to eat dinner now.
Here's an replacement carb made by Stens, a well known manufacturer of aftermarket parts: http://www.ebay.com/itm/Stens-Carbu...373030?hash=item1c7da9eee6:g:RukAAOSwB-1YrVBB
And in case you want to spend more and get a genuine Tecumseh part - http://www.ebay.com/itm/NOS-oem-Tec...894308?hash=item3f727f7124:g:hbEAAOSwUKxYZsid
There are much cheaper ones available, but most of them are low quality Chinese imports. Stens is one of the top aftermarket brands when it comes to mowers, you shouldn't have any issues with their parts. :thumbsup:
Now, as to removing the carb. This is a weird design, if you look closely you will notice that the air cleaner studs are actually bolts, even though the ends do not look like conventional bolt heads. You should be able to remove them with a small 6 or 12-point socket. If that doesn't work, you may need to get a Torx socket to remove them. I'm pretty sure a conventional socket will work though. Click this picture to enlarge it, I circled the bolt head in red:
I ordered the stens kit. Thank you for locating that for me and educating me on the differences.
I spent hours upon hours upon hours for a how-to on removing that specific carb and your red circle with an arrow is all I needed. Thank you for the illustration since I'm still learning the part names. You've been so helpful! I will post when I get the new carb installed. I'm going to redo the tank and get a new fuel line in the meantime. Keep it clear until the carb arrives.
Why are you replacing the entire carb when all you need is the bowl assembly, and don't even have to remove the carb to install it. All the jets are contained in the bowl, there is nothing in the aluminum part of the carb.
He already cleaned the bowl assembly and it still wouldn't start. I figured since he hasn't worked on a mower before, it would be easier for him to go ahead and replace the carb rather than try to rebuild it.
Replacing the carb will also eliminate the possiblity of him re-assembling it incorrectly. It will also ensure that there are no warped gasket surfaces on the carb. And if these carbs are anything like the ones on the LV series engines, it will save him a big headache trying to make it run right. :thumbsup:
When you clean the tank, make sure to rinse it several times with new, fresh gas to get rid of any traces of water or contaminants. You can do this by putting a small amount of fresh gas in the tank, blocking the holes and shaking it vigorously. When shaken, it will pressurize the tank slightly, so release the pressure before continuing. Then dump the gas out and repeat 2-3 times. You definitely don't want any bad gas in your new carburetor! I use a funnel and an old gas can to hold the contaminated gas.
Also, make sure your primer bulb is in good shape (still good and flexible) with no cracks.
the reason I said that was because he had already had the bowl assembly off, and it just snaps into place. The carb cleaner could also swell the rubber seat for the float, which will shut the fuel flow off into the bowl.
