ScottyGoggles
Hi Guys,
Over the last month I have started having problems with my Honda HRZ216TDA mower.
1. When I engage the self-propel bar and I lift the tires off the ground the back tires spin like they should. when I put them down on the ground they stop spinning, as if the ground is creating to much friction for them to over come. I tried this again on the concrete and the mower would go forward on its own but not near as fast as it used to.
2. When I disengage the self-propel bar and I try and pull the mover backwards the wheels try and lock up. when i prop the back of the mower up I am able to spin the tires backwards but it is very difficult. I just hit them with lithium grease but it hasnt made them much better.
Has anyone ever had these issues before with there mower?
Is it worth trying to fix the transmission or is it better to buy one and install it?
Or is this even a transmission problem?
Thank you for the help in advance.
