riseandrun
Another lawn mowing season has begun... last year my sister in law WAY overfilled her Toro GTS 21 inch rear bigger. Mod. 20622. As much oil as I drained I don't think it could have possibly started. I drained the oil last year and it has sat all winter. I put in approximately 21 ounces and after priming through spark plug it finally started. After idling for about 1 minute, I dropped the handle to engage the blade and the smoke was even worse. I'm hoping I haven't made matters worse. Is there oil " somewhere" I need to get out before I try starting it again? FWIW the lawnmower has been meticulously taken care of before my S-I-L overfilled it. I got the lawnmower because " it won't start". Any advice greatly appreciated.
R&R
Should mention a compression check was 150 lbs. and I believe engine is a B&S
R&R
