I have worked on this project for nearly two years now. They say, build a better mouse trap and world will beat a path to your door. Well, I hope this is the answer. Laying mulch is a back breaking labor intensive job. Putting down 30 yards of mulch is a major undertaking which until now requires a massive amount of labor. There has never been any other way except pitch fork it into a wheelbarrow and dump it. Repeat the process a thousand times and your done. Using a tractor front loader is just not allowed by home owners. It just tears up their yard. But if you could do it with the riding mower you used to cut their grass this week how could they object? This scoop is designed to fit for now ( Husqvarna and Sears models) from 2006 and up. Hopefully later, many more. It has a 150 ib. capacity. Lifts over 12 inches above the ground and holds about five cubic feet of mulch. Is electrically operated up, down, open and closed in 5 seconds. As the bucket lifts it also move it back close to the mower. Reducing the weight overhang as much as possible. In the up position it is within 4 inches from the hood. With a full 12 inches of height you can drive right up on the mulch bed and put it about anywhere you want. Plastic wear guides are installed on the bottom of it so it never drags on the ground (driveway or concrete). Six scoops is one yard and it can lay down 5 to 7 yards an hour. The scoop is 44 wide, 16 deep and 15 inches tall. Depending on the distance from the pile to the beds. For those of you who are in the commercial landscaping business should have this figured out by now. At the average cost to lay mulch this makes a riding mower produce $150 to $200 an hour. So take a look and give me your thoughts.
