primerbulb120
Ok, I'm listening. What does $3k get me that $2300 won't?
If I told you, you'd want a 3K mower. :laughing:
Just joking. In general, you'll get a better quality unit with more features. Fabricated deck instead of stamped, sturdier frame, bigger tires, better hydros, you get the picture.
I did a search on your local Craigslist and came to the same conclusions you did. No promising deals. I guess I'm spoiled with Florida Craigslist where you can find 100+ ZTRs for sale at any time of year. :laughing:
If you decide to go new, I think you should purchase one of these units:
Toro Timecutter SS4225: https://www.mowersdirect.com/Toro-74721-Lawn-Mower/p15362.html
Cub Cadet RZT L 42: https://www.mowersdirect.com/Cub-Cadet-17BRCACS010-Lawn-Mower/p15453.html
As far as which one is better, I can't really say. They are very close as far as specs are concerned. Use the Mowers Direct comparison tool to compare the two and you'll see what I mean. I would probably go with the Toro because I like red better than yellow. :tongue: For you, it probably comes down to which one is more readily available. Parts support is probably cheaper and better for the Toro as well. Based on the pictures, I think the Toro would probably cut better due to deck design, but since I've never used either of these mowers I can't say for sure.
I would stay away from Husqvarna. Their commercial ZTRs are good units, but I'm not impressed with the quality and specs of their entry-level models. Just my :2cents:
