I would but I traded the SD in on a new Fastrak 54" Friday...so I no longer have it. I did get to mow with it after the mods but in my mind I was still thinking that this is still not over. It did do very well but one thing that still bothered me was the build up under the deck each time I mowed......just had enough of it! Do a search on here "54 raptor sd mods" this is where I got the idea from. I did cut the discharge chute flush with the deck opening, I think that was more help than anything.....opened up the flow with less restriction on getting the cut grass out, but it does throw the grass a lot futher and higher up, so keep that in mind before you consider it. But my real advice is upgrade to the next level which is the Fastrak, one time mowing with it you'll understand why I suggest it. No comparison between the two mowers.
I know it's more $$ but getting the job done means more to me. It only rains here 2-3 times a week and it's almost impossible to keep up. Never seen so much rain in normally a dry summer. My dealer gets a lot of complaints on the raptor line up, so much that he is considering selling the Fastrak and on up but will special order the raptor-sd if that is what the customer wants.
Good luck if your having issues....it will try your patience for a $4000.00 mower!!
