weedeater
outdoordoug
Can't find a more recent thread so posting here, hopeful. Also seems like consensus is gas all the way, but does anyone have experience with battery powered models? Was checking out some reviews online, but figured I'd see if anyone here has had one! I know the battery life won't be amazing but our yard isn't too big.
The reviews I found:
http://shedheads.net/best-battery-powered-weed-eater-2017/
Lawnboy18
Dewalt are liked on Youtube.
You could consider buying a trimmer that is made by a company that makes other tools (drills, saws, etc.) That way it's one battery for everything. I personally like Makita.
outdoordoug
Good call, going to have to double check my cordless tools and see if they're not too old and can find a whacker that would be compatible. Thanks!
Archie06930
My latest weed eater purchase was to invest in a Sears battery powered weed whacker and I am really happy with it. It's a lot better than any gas model I've owned because of the weight difference, the fact that I don't have to screw with engines being hard to start, mixing gas and oil to feed it, etc. The model I bought is the 40 Volt Lithium battery Max model. Now, having said all that, I should tell you I bought it 3 years ago, and this past year had to replace the cowling that guards the string and keeps it cut to the right length for trimming, and I also replaced the spool. Both purchases replaced worn out plastic parts, and it trims every bit as well as it did when brand new. Those parts only cost me like, 20 bucks with free shipping from Sears Parts Direct, which is usually the most expensive way to go, but for some reason these were very reasonably priced.
I would definitely go with this string trimmer model (I keep about 2 acres manicured so I bought an extra battery) over any gas powered string trimmer. The old WeedEater Featherlight trimmers (which they don't make any longer) were half way decent gas models, but none of any of the full sized gas trimmers I've tried are nearly as good as this Sears battery powered unit in my opinion.
ilovelawns
I was reading through this thread, and it hasn't been updated in a couple years so I thought I'd poke my head in. I just bought a Black & Decker LST300 based on the reviews I read here:
https://woodworkingtoolkit.com/best-battery-powered-weed-eaters/
I'm pretty happy with it overall, thought the battery does take a while to charge, so I ended up buying a second battery so I could keep one charging while the other is in use. With that little trick in place, I'm very happy with it.
Archie06930
Still very satisfied with my purchase, I've bought an extra spool and spool cover to replace the worn out originals, but overall the machine works as good as it did the first time I used it. The second battery works out perfectly. By the time I've completed my weedwhacking chores up front, it's time to change out the battery and start on the back yard.
7394
Echo 225 & it has a 5 year warranty as well.
I have a Shindaiwa T235 & it is a cousin to the Echo 225. Love it.
Actually the Shindaiwa is probably the same Echo just in drag. Both companies have merged.
I believe that warranty is just a consumer warranty. Under commercial use the SRM225 only makes two or three year before the cylinder plating wear through leading to PNC replacement.
logert gogert
hi,
im 13 so take my opinion lightly
i have a decent lawn care business in my neighborhood and i have about 12 yards right now, so when it comes to lawn equipment, i kind of know what I'm talking about, i have tried many weedeaters, and right now i think the best bang for your buck would be ( i have this seedeater ) a troy built, i got mine at home depot for 100$, its a 30 cc, straight shaft trimmer, its very powerful for its class, it can power through surprisingly very tall grass, one time i had to do someones back yard yard and the grass wass about as tall as me, and I'm 5'3, and it went through it very well, its very light and easy to use, but personally i would not get a "weedeater" brand trimmer, i have not had very much luck with those as for mine did not last very long, and it wasn't very powerful.
heres the seedeater that i have:
SALETroy-Bilt 30 cc 4-Cycle Straight Shaft Attachment Capable Gas Trimmer with JumpStart Capabilities$99.99$180Home Depot(692)Free shippingFor most items:90-day return policy
