fkovacic
Hi, I have a Lawnboy model 10523, 1997, 3 speed self propelled transmission that is difficult to shift between gears with the control cable. I have take the cable off and lubricated it at the top and bottom with a penatrating lubricant. I also took off the transmission selector from the transmission gear and cleaned it. It has improved but not that much. I don't know how easy it should be to shift through the 3 gears but I would imagine it should be fairly easy, mine binds when trying to shift. Is there fluid that the transmission gear unit should be filled with, if so with what? I suspect it has to do with the gears inside that transmission. I have a belt driven transmission. I have also tried shifting the transmission by hand without the shifter cable attached and it binds. What do I need to do to make it shift easier??
