fkovacic
Hi, I have Lawn Boy model 10523, 1997, self propelled. I have clean the plastic type carburetor but I am not quite sure how to set the speed of the blade. It seem that when I have it in fast and shift it to slow, I don't hear a difference in the speed. If anything there very slight difference when adjusting the lever from fast to slow or slow to fast. I have checked the vane spring and its not broken but not sure if it weak though. I am not sure how to adjust the click type of adjuster on the vane. I do understand that when the the speed is on fast the governor tension should be stiffer the when the speed is on slow. Can anyone guide me on how to solve my idle speed concern? Otherwise my F engine LB starts fine, and runs fine but can't seem to resolve this idle speed concern. Thank you.
