2smoked
- Aug 1, 2014
- Threads
- 13
- 238
After a lot of searching, I finally scored a bricktop model for my collection. This was a Craig's List posting that nearly ended up in a dumpster. It had been sitting for years and all it needed to get running again was a good cleaning of the tank and carb. I installed a new air cleaner element and fixed the rewind. The motor has good compression and is very tight and runs sweet. I've used it twice so far for leaf pick-up. Cosmetically, it's a bit rough but I just might leave it this way. Maybe a repaint in the future. Next spring I will probably bronze bush the wheels and give it a more thorough cleaning. I'm glad I found this because these have not been turning up around here much anymore.
