Hi Betty,  Question, do you have two belts?  One for driving the tractor and one for driving the deck.  I had a problem with my 96 Craftsman, it has a 46 inch deck and I was blowing mower drive belts one after the other.  I found that it was caused by a retaineer at the idler.  It's an "L" shaped belt retainer bracket.  It was very slightly bent and was cutting the belts.  I made a new on and allowed a little more clearance for the belt and that problem was cured.  It took a number of belts before I was able to figure it out.  Almost parted with the tractor at that point.
Last year I started having problems with belts again.  The first one was a fluke a stick got caught in the primary mower drive belt and stopped the belt it started smoking and ruined the belt.  Ok, my bad I should have cleaned the deck better.  Decided that I could save money if I bought a replacement at TS.  Well although the price was right it only lasted an hour.  Thought if I bought a inch longer belt it would cure the problem, same results.  Both of these belts were 1/2 inch wide.  I then went to a 5/8 inch belt again the same results.  I was getting a little (a lot) disscusted I needed to get this machine back up and running.  I decided to bite the bullet and buy a belt from Sears.  Well it was the same length, but it was a little different in width.  I installed it and crossed my fingers and voila it worked.  This cemented the decsion to replace this mower as my first line of attack.
Hope that maybe some of this helps.  Oh, and welcome to the forum.
