Westwood 1200
clicon357
Hi, I have a Westwood T-1200 ride on, 12HP, electric start mower. Whenever I put it in reverse the belt jumps off, any ideas? Thanks.
check the support bolts on the front corners of the transmission. if there not connected the transmission will flex the frame causing the belt to come off the bottom of the transmission pulley
clicon357
Thanks for that I'll take a look. I contacted Westwood here in the UK and they sent me a full Instruction Manual and Spares List for the mower which was v.good of them. Will let you know how I get on. Cheers.
