need help finding engine 4 my chripper
socasml
i have a yard mach with a blown moter rod went out the side of block but the crank is still ok the moter is a 5.5 briggs and straton model 13 72 13 typ 1313 b1 any help out there
mechanic mark
Post Yard Machine model & serial numbers from data plate or sticker.
That's a fairly common engine. I would go to your local repair shop and see if they have any mowers around with bad drives. Should be able to get a used engine fairly cheap. Any over way would be putting more money into your unit than it is worth.
socasml
there was never a plate stamped on chipper but the enging is a model 13 72 12 typ 1313 b1 code 990216ya
