turbofiat124
I built this last summer but just got around to taking a photo of it. The cheapest bumper I could find was around $60 which was a piece of bent tubing with the ends flattened.
The only thing is, the metal I sourced from dumpster diving at work seems to be thicker than the metal used on the frame. So I wonder if I were to hit something hard, the bumper might survive but the frame may bend.
The hood barely opens all the way. I should have made the mounts about 1" longer. I also drilled some holes and was going to mount some extra lights but after the fact I realized the hood would not open at all with lights mount. Unless I mount them below the bumper.
