rickmrickm
- Jul 13, 2016
- 4
Hi,
I'm new here (and to this) so my apologies if I do something wrong.
I have a Scag Tiger Cub that has developed an intermittent problem that I'm chasing down.
The mower starts fine provided the safety switch conditions are met. Everything runs great, and after half hour or so will shut down, no warning, just simply mowing a straight line. No sputter or misfire... it's just as if I turned the switch off... dead. If I crank it to restart, it just cranks... no fire. I know... check for spark... I didn't get to that, having only 2 hands. If I let it sit for an hour or so, crank it... it will start up again, and repeat the whole thing. And it always seems to happen when I'm at the far end of the property. I assumed if it was fuel based it would give some warning like sputtering before dying. Maybe I'm wrong here.
I read something about the "white wire in the main harness"... if it's grounded, the engine doesn't run. Today when the problem occurred, and after its hour sit, it started. While running I checked the white wire with a voltmeter... black to frame ground and red to the white wire... zero volts. So, I question the validity of the "white wire grounded = no run" theory.
I'm questioning 2 things... fuel... there is a filter between the fuel tank and the fuel pump. After the fuel pump it's a straight line to the carburetor. I put a clear filter in that line, to be able to see if the pump is pumping... seems to be.
The other question is the Interlock Module... a "black box" with 8 wires. I can't find anything of technical value on this module... I'd love to find a schematic!!
Does anyone have any technical info on this module? Like what's supposed to be on what wires, when? I'm half tempted to get hold of an old one and dissect it to a schematic. But maybe someone already has info on this.
Another thought was... are these known for float bowl needles hanging up? (I'm assuming there's a bowl/needle setup) If the needle sticks in the UP position, could I be using a bowl-full of fuel, then not refilling the bowl?
Well, I'm really interested in knowing what some of you who are more familiar with mowers than I am have to say.
Thanks,
Rick
Thanks,
Rick
