Gravely Zero Turn 260Z Lube question
wildfiglane
My owners manual said there are grease fittings at the area, where the mower meets the frame, its called " push arm pivots". There are no sign of fittings there. Also its says to grease the front wheels , its called "castor pivot" there are no grease fittings there either. any suggestions?
Midniteoyl
The manual I found doesnt say there are fittings.. It does imply that you use spray lube on the deck pivot joints though.. For the front casters, removing, greasing, and reinstalling looks to be the way.
I dont own one though.
