a_gunslinger
Bought used, worked great for a while now speed control not working.
HRT2162TDA
Serial MZCG-6974996
Clues:
Its the inside of this speed change knob item #15: Honda Power Equipment - Parts Look Up - Official Site
Cant quite see the crap plastic inside but there is a plastic tension spring that sticks in a groove that seems, well, useless:
http://i.ebayimg.com/images/i/400407...-1/s-l1000.jpg
Not sure if the issue is on the change control isde or under engine. But hoping to get the most likely cause from experts before guessing.
From underneath it looks good, spring in place, but cant see entire tranny and control arm. And for the life of me I cant see how the bottom deck components come part to even get to where the speed control cable attaches.
Any insights? Refuse to let it die ;^)
HRT2162TDA
Serial MZCG-6974996
Clues:
- Pulling clutch lets it pull backwards
- I took the crap plastic change control apart at it seems like the plastic coil is always out of the groove its supposed to be in
- Putting it back in allowed it to work, but no 2nd or 3rd speed then 1st fades out also, but then it stopped
- PTook it apart and plastic tension spring out of the groove again
