Front deck adjustment on a Toro Time Master
jekjr
I have a problem with my Toro Time Master Walk behind keeping the front end adjustment in place. It drops to the bottom as you mow.
Has anybody else had this problem?
I have not disassembled it yet to try to figure out what is going on.
Anybody running one with the same issue please give me input as to what you did to reconcile this problem.
Thanks.
So the problem is with the height adjuster? Is it loose? I broke the one on the rear on my mower but the front has been fine.
Actually it does not seem to be the lever itself. I am thinking something is work/cracked ect that holds the wheels in place. I still have not had time to take it apart and look close at it. Maybe tomorrow.
