New guy here.  I've got a Craftsman 6 hp push mower.  I'm not that knowledgeable about engines, but through trial and error and watching lots of Youtube videos I've gotten to the point where I can take apart the carb and clean it out pretty well.  I've even replaced the plastic tube that runs up the middle (name?) as well as primer bulb.
One thing I haven't figured out is how to remove the silver disc (see pic) and clean inside. I assume that is how I get access to those teeny holes visible in the throat of the carb. I've managed to get a fine copper wire into the holes by approaching through the throat, but I'd like to do a more thorough job of cleaning in there. I've looked at lots of repair videos on the web but haven't seen any that get into this. Part of the problem is that I don't know what the disc is called so I don't know what to search for. There's a similar disc on the underside of the carb.
So can someone explain what to do here or point me to some place that explains it. Is there a special tool that's needed. Thanks a bunch.
Steve S
Steve S
