need help with troy built/ brigg carb identification
hemidak
I'm working on a troy built 2700 psi pressure washer with a briggs and stratton engine. I cannot find a model number on the engine but need a new carburetor for it since I accidently cracked it. The number 799154 is on the carb but when searching for it diferent carbs come up. Not sure where to look. I pulled the plastic cover from the top but no numbers anywhere on the engine. Any help appreciated
Here's a video from Briggs and Stratton on where to find your model number. I know it's for push mowers, but if your pressure washer has a vertical shaft engine the model number will be in one of these places:
https://www.briggsandstratton.com/na/en_us/support/need-help/push-mower-engines.html
If the above video is not helpful, try this one:
https://www.briggsandstratton.com/na/en_us/support/need-help/other-engines.html
