Shane,
I like my Raptor SD. I got the flex forks from the get go and I really can't complain about the ride so far. The bulk of my yard is fairly smooth in relative terms where I can run it wide open if I want without bouncing too much. I keep all tires at 10 PSI. I do see the flex forks moving a bit but I'd admit it is hard to tell if they do much (nothing to compare with). In the really bumpy section of my yard there are too many obstacles to run very fast, so again, happy so far. I may spring for a seat suspension down the road but for now I am OK.
I only have one minor gripe and that is with the discharge opening. I anguished over it before I purchased but decided for the amount I need to cut the extra bucks were not worth it. The majority of the time (98%) there is no issue. On the occasional heavy salad cut it starts to clog a bit in that back corner. I've been thinking about taking a torch to it to open it a little more. Time will tell. Keep us posted on your new unit.
Thanks .......... Rhett
