20hp vangaurd governor ?
napaman9
I rebuilt a 358777 engine but the problem is my friend pulled the governor linkage off the shaft ,I tried to adjust it with little success either speed is low or revs ? any help is appreciated in advance
Post model xxxxxx, type xxxx, trim xx from engine, need all numbers.
1. Loosen governor lever nut. Push on governor lever until throttle is wide open. Caution: Do not bend governor link or distort governor lever.
2. Use a screwdriver to rotate governor shaft counterclockwise as far as it will go. Torque governor nut to 70 in. lbs.
3. Install throttle & choke choke control cables & check for proper operation.
