TimGoodman
- Aug 9, 2015
- 13
I got them both home Wednesday and under a shed. There is a drain plug on the Hydraulic tank. The owner told me she wanted the 721d so that means I'm getting the 928d. I started on the 721d last night. I replaced all the rubber fuel lines and fuel filter, cleaned the fuel tank and filled with fresh diesel. I replaced a couple relays that were missing. I pulled them from the 928d and went to the auto parts store for new ones. With fresh battery in place, I hit the ignition switch and nothing. Although the glow plug system works. I jumped the starter solenoid and it spins, but is not engaging. I'll be taking it off and to the starter rebuild shop Monday.
What is the least expensive compatible hydro fluid for these machines?
Thanks
Tim
The pic is of them at my shop.
Thanks
Tim
