Grassbandit
- May 20, 2012
- 151
Stihl FS80 Trimmer.
When the starter rope is pulled it spins freely. Upon inspection I noticed the pawl and carrier were damaged. The nut in the middle was separated from the rest of the cup.
So i replaced the whole assembly and after 1 session of use the same thing happened. Clutch carrier broken once again.
What is causing this issue?
