Repairs hydraulic valve
blueeyes
Does anyone know where I can find a hydraulic valve for my c-141, the part # I have for valve is 106680,k and part # for overhaul kit is 110976 which you cannot find anymore. Does anybody know where I can find them. also need hydraulic hoses part# 106421,need-1, 106420, -need-1, 106651-need 2. Thanks in advance for your info
The part number for the valve is superseded to 99-5363, but sorry it is also NLA. By chance is there a name and/or part number on the valve which we might be able to cross reference? If you do find a valve, you can have the hydraulic lines custom made. I'll try to remember to look through the old service manuals I have at the shop, to see if I can come up with anything. Please post the model and serial numbers off the tag under the seat.
blueeyes
Here is info from tag:Sundstrand
90-1173-LH
04-UL
23176
31029-02
Here is info off of valve: WARD CO.
0934128
This is all info I could find, hope it will help you. As farer as getting hoses made the paces around this area does not have correct ends, the ones they have are to long to use.
