Mad Mackie
- Jul 11, 2011
- 1,851
There are other cadmium plated parts on the machine, are the oxidized also?
Part of the engine serial number is the manufacture date code. I'm not familiar with Kawasaki date codes, but this will tell you when the engine was manufactured which will give you an idea when the machine was assembled.
I would bring up the clutch engagement problem with the dealer initially and as the conversation progresses, bring up the oxidation problem on what is a new machine. I know what they will say as I have been on that side of the counter.
Your machine could be several model years old as some new models have Kohler 700 series engines on them.
I have a 2012 X-ONE that is stored in a shed with a dirt floor and the engine is cleaner than yours.
Just my thoughts!!!
In 2008 I passed on a machine that was new old stock and was a 2004 model. Although the price was OK, I wasn't OK with an engine that looked like yours and rust on some of the parts on the machine.
The bottom line is that the machine should operate as intended!!!
Just my thoughts!!!
