msmallenginerepair
Hi guys and gals, a client of mine just bought an Ariens tractor with a 2015 Briggs, MOD: 33R877 0009 G1, CODE: 150109ZD. He called and told me that the starter was overheating and wouldn't crank the engine over. I took a look at it and found that the engine was locking up on the compression stroke and figured it just needed a valve lash adjustment. I told him to get on the phone and let the warranty work, but whoever he spoke with told him that the valve lash service wasn't covered under warranty. So I decided to take a look. The service manual tells you to:
1. Turn crankshaft counterclockwise until piston is at top dead center on the compression stroke. This prevents the compression release from holding the valves open.
2. Insert a narrow screwdriver or rod into the spark plug hole as a gauge, then slowly turn crankshaft counterclockwise until the piston has moved down the bore by 1/4
3. Using a feeler gauge, adjust rocker nut to obtain the clearance as listed (.003 - .005 in. for both intake and exhaust)
4. Hold rocker nut and tighten the rocker ball setscrew to the torque valve shown in Section 12 - Engine Specifications.
5. Check clearance again and re-adjust, if necessary.
6. Repeat for other valve.
I did this, put the spark plug back in, turned the engine over by hand and it is still locking up on the compression stroke. So then I turned to all of the old tricks up my sleeve and nothing has worked so far. Another tech told me that the compression release spring on these engines have a tendency to break or come off. What do you guys know about this? Any other suggestions? I know some of you will probably say, "It's under warranty, just take it in to an authorized dealer for repair", and I agree with that. But I would like to know more about this issue and gather as much information for my personal use as possible. And yes, I called Briggs. They told me, ..."just take it in to an authorized dealer for repair". No help. Thank you in advance!
