A question on the stacking of the blade holder, spring clutch and driven disk onto the pulley assembly. A diagram that I downloaded from the from does not show a thrust washer between the driven disk and the pulley assembly. The Honda parts diagram from their website does. Is there a thrust washer. Also, is there a 10mm washer that goes between the blade holder bolt and the blade holder bearing. I would look at my existing setup but the blade holder bolt broke when my son-in-law was borrowing the unit. I have the main assembly but lost some of the other parts.
Thanks
Thanks
