Engine Replacement Ignition Coil for a Lawnboy 10515
Yes that is the correct part number if you can find it. It has been superseded to Toro part number 100-2948. Another part number you can use is 440073. Don't be shocked when you see the prices. The Toro part is easy to find, but runs about $100, the other two are cheaper, but much harder to find.
Thank You Very Much, I appreciate the help. Is there a PDF anywhere of all the part Number for lawnboy models? My model was built on 1994 is there a difference from 1993?
