Carburetor Replacement Walbro LME 5-250, Tecumseh SBV-271E 4331F
jimmydeanlarson
I am doing some volunteer work at an outdoor club and they have no mower so I had been looking for a cheap mower to flip. I have no experience other than monkey see monkey do from some youtube videos for flipping mowers. I found a snapper rer 2811x5s at a garage sale, i could get it to fire but not run at first so I cleaned the carburetor. It is severly pitted and the threads the bowl nut go into are all but gone and wont thread. since the cleaning I was able to put fuel in and get it to actually run for 90 seconds. My thoughts are to replace carb but I am not finding the replacement walbro LME 5-250 available. Can someone help to find the correct replacement. Not sure that it matters but in researching this seems to be a replacement 8hp engine rather than the 11hp that was original. Its in pretty good shape for 1980 something. Thanks in advance.
Could you check your Tecumseh number. I get SBV as short block engine.
I dont know the manufacturer for sure but I have looked over the engine and this is the only tag i can find, its an aluminum stamped tag bolted on an engine mount. This engine I am pretty sure is a replacement. It has been painted white so if there were another tag it may have been removed. Do you feel that this tag is not the right one?
I don't know about being the "right one"
but I can only find parts for the short block part of the engine with that number.
When searching this here is something I found but I am just not certain. First is a conversion chart, second is the parts diagram that looks like the one I have, third is the carb that it says. However my carb says walbro LME 5 250. Maybe this makes sense to you.
Tecumseh Shortblock SBV-271E how to cross reference - Tech Support Forum
Tecumseh TVM170-127000C - Tecumseh 4-Cycle Vertical Engine Engine Parts List #1 Diagram and Parts List | PartsTree.com
Tecumseh Part 632991, CARBURETOR | PartsTree.com
I found this using the old part number...does it look the same?
Tecumseh carburetor part # 632237 | eBay
