briggs not running good
basstracker
I have a 6.5 hp push mower, the carb has a flote. I put a new kit in it but it still don't run like it should. i put the seat in with grove facing the bowl,is that right or does it matter. thanks
Rings should face the carb body. Here's the procedure I recommend.
Needle and seat replacement
Remove the carb, and then remove the float bowl. Check the float bowl jet (which is the bowl screw) and make sure the jets both horizontal and vertical are clean and open. Tip the carb upside down and remove the float pin and float with needle attached. Look in the float needle passage and you should see the red float seat at the bottom of the passage. This is where a #5 crotchet hook would come in handy as you need to remove this seat. If you have no hook, but compressed air, you can blow through the fuel inlet and try to pop the seat out. Put your thumb over the passage to prevent the seat from flying who knows where. No air or hook try bending a stiff paper clip to dig the seat out.
I would either give the carb a good 24 hour soaking or have it ultrasonically cleaned at this time.
With the seat out clean the passage way with carb cleaner. Now you must find a drill bit slightly smaller than the passage way, to be used to press in the new seat. Apply a very, very small amount of a very light lube to the new seat. 3-1 oil or lighter, to help seat it better. Carefully insert the new seat in the passage way with the rings on the seat down toward the carb body. Slowly and carefully force the seat down with the back end of the drill bit. Once it is seated, check to see that it did not flip and the rings are up. *Next check to make sure that the float does not have any liquid in it. *If it does, replace. *If everything looks correct, attach the new needle to the float and install with the float pin centered. It everything is correct, the float should seat level to the carb body, when looking at it upside down. If everything looks good reattach the float bowl, making sure that both the bowl gasket and the nut gasket seal properly. Reinstall on the engine and test unit. Remember to have patience and take your time. Good luck, but I don't think you'll need it.
PS: *On the side of some Tecumseh carbs you will find a plastic cover. *Under this cover will be an idle jet. *Remove it and check to see that the jet is open both horizontally and vertically. *You should be able to push the old float needle wire through the vertical opening.
thanks for the reply. I turned the seat over and the float set level like it should but it still kind of spits and sputters. it runs good enough to mow with but its not right. Im not shure it's the carb.
Post all engine numbers from engine data plate. Absolutely does matter. Check air filter for replacement. Adjust valves per manual specs. after posting numbers.
all the numbers i could find were on top of motor, briggs and stratton 650 series 190cc j1940
Look on the plate above the muffler for more numbers. You should have needed these numbers when you got the new needle and seat.
Going to ask a couple of questions to solve this problem. Did you check and clean the jet which is located in the bowl screw, which holds the bowl to the body? Are you sure the float is level or slightly rich? Are you sure you are running at the proper RPM's? Should be about 3100. Are you sure you didn't scratch the seat when you removed it to flip it over? I rebuild at least two of these carbs every week and if the needle, seat and float are installed correctly in a cleaned carb, it should solve your problem. I suspect you float is not level.
I did clean jet, it don't have a throdle but its running fast enough to mow, the float is slightly elevated holding carb up side down.
