Honda mower engine won't start
banjomaniac
I have a craftsman push mower with a 5.5 Honda engine and it wouldn't start so I put on a brand new carb and dumped the gas and put on new fuel lines. Still won't start but it will run a few seconds if I spray start fluid in carb. Its like the gas isn't getting into the engine? Any ideas? I put on a new plug and loosened the carb bowl screw and it has gas so I'm at a loss.
logan01
Is the fuel gravity fed from tank to carb, pickup tube/line, other? Is fuel even making it at all to the carb?
lugnut1
first thing we'll need are the engine numbers (model, serial)
(so we know exactly what were looking at in order to solve your problem faster)
engine check:
1.spark plug condition (dry or wet)
2. is there a good draw on intake stroke
carb check:
1. main jet (plugged or restricted)
2. gasket/gaskets sucking air
3. float sticking
4. choke working properly
5. electric fuel solenoid working correctly ( if equipped )
some possible fuel issues:
1. bad gas
2. air filter dirty
3 debris in tank
4. fuel filter (plugged or restricted)
5. fuel line (plugged or restricted)
6. shut off valve working correctly (if equipped)
banjomaniac
IMG_20150715_183057_255~2.jpgCraftsman mod. 917.378501 ser. 081103M 017329 I put In a new spark plug, new fuel and lines and cleaned the old carb BEFORE I bought the new carb and installed it but I used the old gaskets. Can that cause it not to deliver gas to the engine? Maybe it is sucking air like suggested. I will buy some gaskets and try that. The spark plug looks dry after several pulls trying to start and like I said, it will fire right up with a squirt of starting fluid.
Banjomaniac
Vervepipes
Re-using old gaskets can be hit or miss, If everything else is new except the gaskets it seems like a good place to check.
logan01
If the old gaskets are still on, get the mower running with a few squirts of carb cleaner, etc and while running spray carb cleaner around the gasket. If it changes pitch, rpm, etc, you have a leak.
banjomaniac
It won't start at all and only run a couple seconds with starting fluid.
lugnut1
are you trying to start it with air filter on or off?
lugnut1
need the numbers off the engine also
check that your choke is working correctly.
banjomaniac
Choke is working fine. There is a plastic spacer between carb and engine that I'm also replacing tomorrow. Maybe it will run then. I will update.
Banjomaniac
