J Jstinson Forum Newbie Joined Jun 29, 2015 Messages 5 Jul 13, 2015 #1 I have a cub cadet with a Kohler engine it is back firing through carb any and all help will be appreciated thanks jeff
M Mikel1 Well-Known Member Joined Jul 21, 2013 Messages 897 Jul 13, 2015 #2 I would check the flywheel key first. If that is good then check valves. Not sure what Kohler you have.
Catherine LawnWorld Support Joined Jun 13, 2015 Messages 1,683 Jul 13, 2015 #3 Hi and welcome to the forum! :welcome: I'm moving your thread over to the Cub Cadet section to see if we can get you some more input on that problem.
J Jstinson Forum Newbie Joined Jun 29, 2015 Messages 5 Jul 13, 2015 #4 Mikel1 said: I would check the flywheel key first. If that is good then check valves. Not sure what Kohler you have. Click to expand... its a kohler commander is all I know took it off and put oil seals in front and rear it cranked up when I put it back on the frame then quit now all it does is backfire through the carb im stumped
ILENGINE Lawn Royalty Community Leader Joined May 6, 2010 Messages 12,060 Jul 14, 2015 #5 Improperly torqued flywheel causing shearing of the flywheel key. Pretty common problem.
