Raptor Heat Shield
Rob45679
Installed the heat shield my dealer warrantied for the burnt spots in my grass. It came with the shield and hardware. No box or instructions. But it was a direct bolt on. Took about 3 min.
attachment.php
attachment.php
[/IMG]
Did you show them pictures of your grass or did you just tell them? I'm not having that issue yet but would like to install the guard to prevent future problems.
maybe i'm missing something, but how did the exhaust burn your grass??
I guess burned was the wrong word to use. It dehydrated the grass under the muffler where I had parked the mower. It would take a couple of days for the spot to show. The spot would green back up after a week or so.
I ordered one for my 48 SD.It does not look like the one in the picture mine has cut outs for the bypass valves.My invoice says EXC 120564 HEAT SHIELD MUFFLER if that helps. it was 39.80 plus 3.50 shipping.
Just a quick question, in the very first picture there appears to be a bolt in the trailer hitch hole. Is this part of the deflector assembly? If so do you have to purchase a new type trailer hitch. I own an Raptor SD 54. Thanks
