B&S won't start hot
vincent52100
Good evening. I have a B&S 120000 series vertical shaft, OHV engine that won't start when hot. I've tried all the tips I could find with no success. I've cleaned the carb, replaced the rings and head gasket (no ridge on the cylinder), set valves to .006, replaced the coil, tested the flywheel magnetism, ck carb spacers and replaced the plug. It has fresh gas and clean air filter. I'm not sure where to go from here. Any help would be greatly appreciated!
Try spraying some starting fluid thru carb or a little fuel, does it try to start?
This is sometimes an indication of carb float needle leaking a little flooding the engine. I would turn off gas a few seconds before stopping the engine and see if that helps. No gas line shutoff, clamp the gas line. Test above should help indicate if my suggestion might be good. Fixing an engine by helter skelter replacing parts is not very economical, might as well buy new engine.
Walt Conner
Actually the engine was given to me by a friend because it wouldn't run. I could hear blow-by from a head gasket. I popped the head and the head gasket was blown. Since the head was off I did the valves. A lot of carbon so I thought I'd check the piston. The bore was good but the rings were partially stuck. Replaced,re-assembled and tested. The spark was weak so I replaced the coil, good spark. But I do have the hot start problem. It doesn't matter if the gas is shut off or not. I checked he compression and it's the same hot or cold. I think next I better replace the carb to head gaskets although they look good.
Ya I've got a 12M902 coming in that's doing the same thing (hard to start hot)
I don't really care for that model:thumbdown:
will let ya know if I find anything with it.
lugnut
lugnut
Great! let me know if you find anything. One thing I did was put a fan blowing on the carb. I'm thinking that that leads me back to carb isolators. Going to give that a try.
