vincent52100
- Jun 22, 2015
- 7
Good evening. I have a B&S 120000 series vertical shaft, OHV engine that won't start when hot. I've tried all the tips I could find with no success. I've cleaned the carb, replaced the rings and head gasket (no ridge on the cylinder), set valves to .006, replaced the coil, tested the flywheel magnetism, ck carb spacers and replaced the plug. It has fresh gas and clean air filter. I'm not sure where to go from here. Any help would be greatly appreciated!
