neighborbill
- Jun 17, 2012
- 107
I have a Kawasaki FD791D (DFI) engine on my scags.
Everything seemed to be OK, but now the engine is starting to pulsate on me. It's like it is running out of gas and then getting the gas back. Pulses. When it is cold it is better, but after it gets warmed up then it really starts to pulse.
I've taken out the air filter. no change.
I'm assuming that the machine has a govenor (maybe not) and it is holding the rev up and down.
Where do I start looking for a solution.
Pump is fine, injectors are fine, air filter is not the problem, something else is causing the pulse problem but only when the engine gets hot.
Help
Help
