how many horspeower does the HRX217VKA 190cc Honda have ?
gentlejax
  • / how many horspeower does the HRX217VKA 190cc Honda have ?
This is a new to me used mower that was supposed to be needing carb work. I got it running and it pulls pretty hard. beyond any natural speed I would mow with unless I was doing long straight cuts.
anyhow...how many horses is this motor?
The 190 used to be labeled at 6.5 hp.
robert@honda
The base GCV190 engine on Honda's engine site lists the power at 5.1 @ 3,600 rpm, but the HRX mower runs closer to 3,100 rpm. It is, however, tweaked to provide max power at 3,100, so the lawn mower version of the engine on the HRX is probably 5+ horsepower.
Like most modern mower manufacturers, Honda does not publish lawn mower horsepower data. There are too many ways to measure it using a method all companies can agree on, so most agreed years ago to stop. Helps keep
shiftsuper175607
Are you saying your legs aren't long enough?
