It sat for a year and a half. The carb screw just needed some adjustment and she was running fine yesterday. Did my whole lawn with her then she ran out of gas. Filled her up with new fresh gas and now she won't start. If I spray starter fluid in the air cleaner hole she will start up for a second and then die.
- Changed oil since it hadn't been done for ages.
- Checked for spark and it is good.
- Took apart the carb and sprayed carb cleaner until it was coming out of every hole.
- Cleaned the jet on the bottom of the bowl completely.
- Soaked the whole carb in some carb cleaner in a bowl.
All fuel lines look OK as well.
What am I missing here? This is an older model Craftsman 6.0 with larger wheels in the back and I,believe Tecumseh motor. Tia.
