JOHN DEERE F 910 W/ ONAN ENGINE
lag
I have a john deere f910 mower
All of a sudden the mower engine quit running and we cannot get it started back. I think that we have checked the safety switches but may not be sure of all of them. can anyone help us with something else to check or a possible solution.
thank you
thank you
Is it cranking? (motor turning over with the starter)
No noise when you try and start it?
Only making a clicking noise?
Does it have gas?.... Will it start with starting fluid?
Does it have spark?
i did find out that the key ignition is getting power to the ignition but not going out the other side/ would that cause the mower to die. when I turn the key I get no lights on the console and nothing. I can cross the solenoid and get the motor to turn over but will not start.
also I have a loose wirte on the electric clutch. would that cause any other issues elsewhere?
