And you guys never had tranny problems? That's one of my main concerns about the mower
The Turf-Master and Exmark both had there problems when they were first introduced much the same as any mower when they first come out, look at the problems the Raptor had and HUstler just like Toro took care of the issues. Since then I've never had a problem with the Turf-Master tranny in the three plus years I've been using it and the single bail design works great. Most the problems you here about with the Turf-Master are self inflected.
Okay thanks. Price wise is the Turfmaster cheaper then the exmark? Or the same price
There both the same price. You should be able to buy either for like $1699 and of course tax. That's what I gave for mine. IMO the Toro is a nicer mower with the two wheel adjustment rather than three on the exmark and the single bail instead of the dual is easier to use, but it's what ever you like.
The only problem we had drive wise was I had to adjust the cable from the handle one time. I really did not consider that an issue. It works fine.
