Bronco oil drain plug
mdeckeradpro
I have a 2005 Troy Bilt Bronco with a 21 horse Briggs engine. I went to change the oil and when I twisted on the drain plug, it pulled out completely. It is just a pressed in plastic piece, not threaded. I can't get the plug back it. I guess it expanded too much when it came out. Does anyone know what size that press in plug is and where I can find another?
Thanks,
Marc
Please post the Briggs model, type and code numbers. Never seen a pressed in drain plug on that size engine.
Thanks,
Marc
I have a Troy-Bilt mower, the next size up, and the same thing happened to me last year. I think that you will find that the part that plastic thing presses into is still in the block and IT does have threads. I ordered another plastic drain plug off of Ebay, but before it arrived I discovered that a 3/8 hex head brass pipe plug will screw right in and work even better for me.
Good Luck,
Roy
Good Luck,
Roy
If that's the case and room permits, you can install a length of pipe male thread to block / female on plug end, and a plug to make the oil change easier and less messy.
