LX 173 not starting
kamakazee
Used it last week everything ok.
Tried to start today, battery shows 13.1 volts, all grounds are tight and clean. Have power to the starter.
Wondering if the safety seat switch or blade safety switch went bad or something else.
Grass needs to be mowed..
No ideas what to do.
Doesn't sound rite but voltage at the battery 13.4 and at the starter 15.1volts
If the battery was low the solenoid will sometimes click, I'm not here'n anything.
Operate the blade engagement switch a few times, make sure it is OFF!
Mine hangs up occasionally
Push the brake pedal down all the way,
Seat switch made by you in the seat.
