Briggs valve clearance specification.
mxcross
I have a Snapper self propelled mower. I have conflicting information on what the valve clearance should be. Its the Intec Briggs motor with the overhead valves. The model is 128602 0149 E1 051004. Any ideas?
Looks like the briggs repair manual is showing .003-.005 for intake and .005-.007 for exhaust.
mxcross
Thanks. I did see those specs in the Briggs service manual 276781 it had a date of 2009. I looked up the specs in the operators manual for the 120000 model it was dated 2009 also and it said both should be .004 to .008. Also the chart Senior gave link for says .004 to .006. I guess I will go with repair manual. Or I may just call Briggs and see what they say. Thanks for info.
