Last fall I tested that approach with a single 20" rotary mower(Earthwise 24Vdc), But Idid you consider a rotary mower with a couple of caster wheels?
got to thinking about the power requirements and footprint of a +40" cut path in that style
and I lost interest(I also didn't like the noise of even a 20" mowing deck).
I gave George the power to push a 50" plow through 10" of snow, it should have the
power needed to push 3 20" reel mowers with friction drive. with this approach no
extra energy would be needed to power the mowing deck(it would also be very quite),
energy would be needed for lifting and lowering the mower(needed for turns) but the
amount needed would be much less then powering the mower deck.
with that said, plan B is adding two more batteries to power the reel mowers(I already have
the motors) and adding casters.
I'm very skeptical that a friction drive approach is going to give me satisfactory resolutes
but I gotta give it a chance(four weeks at most) due to the energy savings.
While I do force myself to stay on task and not think about the next phase, it does play
a part in the options I test(next phase is using solar cells to charge George's batteries) .
Tommy
