FourtyCaliber
Alright, I'm back. Still have some family issues going on, so not a lot of time to work on the engine. Anyway, I did the valves. I had to grind about .015 off the exhaust valve stem. That produced a lash of about .010. After that, I bought some lapping compound and lapped the lash back down to about .007. The intake was completely the opposite. The lash was about .011. I lapped the valve down until I got the lash down to a tight .004. That was a LOT of work. I made a tool for my drill to "spin" the valve for the lapping. I bought some industrial strength VELCRO and put mating sections on the top of the valve and on the tool I made and then applied the lapping compound on the valve angle. It worked pretty well. I had to use the screwdriver and zip-tie method to remove the valve springs since I couldn't find a spring compressor in 5 stores I went to. Napa would have ordered me one, but it was $50 and I couldn't see that for possibly a one time use. If I ever do this again, I'll buy one. I put a coat of oil on the stems and between the pushrods and ends so it won't run dry when I first start it up. That's where I am now.
I went and got my gaskets today and will put the rest back together tomorrow. I also bought a new fuel line since every time I run gas through the old one, I get little black specs out of it. I cleaned the breather element too. It wasn't bad. I checked the head for warpage on a flat piece of glass. It was OK, so I cleaned the mating surface by running it on some fine sandpaper on the piece of glass. I cleaned the head mating surface of the cylinder with a fine wire wheel.
I'm not sure which torque sequence to use in the service manual for the head, since there isn't one listed for the LH195SP specifically. Is the 200 in-lb spec for the head bolts correct? What is the right torque sequence? Anything else I should know?
Thanks
Thanks
