randy ransome
I can't get the bulb to pump up. I've changed the bulb cleaned the carb, checked the fuel filter, but it will not pump up.
When I pump the bulb you can see fuel start to pump into the line but it stops. If I keep pumping it builds up pressure in the fuel tank.
If I pump it many times then pull the return fuel line off you can hear the pressure release from the line.
For some reason it's building up pressure. If I remove the gas cap and pump it it won't pump up.
I give up. HELP!
:confused2:
I give up. HELP!
:confused2:
