David- Enjoy it then !!!
Buddy
We have a 52" Tiger Cat with 150 Brutal hours on it. The belts vibrated on it right from the start. Personally that is the ONLY thing I do not like about it. It is one grass cutting machine. We run two Kubota mowers as well. In tall grass, especially Bahia the Scag will cut circles around either of the Kubotas.
This may not be your issue but it could help someone else with belt vibration. Sweet gum trees here in my state drop these little spikey balls that are a perfect fit to fly up and end up in the pulley grooves. This causes belt vibration as they stick in the pulley.
Absolutely! Can't wait for the grass to grow high enough to cut again! :laughing:
