Kohler command 27 died on steep hill, won't start now
denalidigger
I have a cub cadet tank m60 with the Kohler 27 hp. I was mowing steep hill, very dumb as it died at top and luckily rolled on all four wheels down.. when it got to bottom I tried starting it up and nothing.. no noise or won't crank nothing.. help please!!
Make sure the pto is turned off, and also check for blown fuses.
The location of the fuses could vary depending on model of mower. Most are located within about a foot of the battery. Could be clipped to a frame rail, could be under a cover that contains the key switch and other wiring.
Now the question should be is, why did it blow the fuse in the first place.
